Need help on automatically calculation
745 1
Jack_Teng
Is there a way that we can automatically calculating based on different conditions
For example
IF
Service: Deep tissue massage
Time: 60 minutes
Result: Commission: 80
IF
Time: 90 minutes
Result: Commission: 150
IF
Service: Pain Relief massage
Time: 90 minutes
Result: Commission: 140
Thank you so much :pray:
Jason
Airtable Employee
Airtable Employee
Hi Jack,
You can accomplish that with a nested IF statement like this:
   AND(
      Service="Deep tissue massage",
      Time="60 minutes"
"Commission: 80",
   AND(
      Time="90 minutes"
"Commission: 150",
   AND(
      Service="Pain relief massage",
      Time="90 minutes"
"Commission: 140"
You can keep adding on conditions as needed - just make sure that you add commas at the end of all but the last condition (e.g. after “Commission” XXX), and add closing parentheses for however many conditions you have (e.g. 3 in the example above).
Jason
Airtable Employee
Airtable Employee
Hi Jack,
   AND(
      Time="60 minutes"
"Commission: 80",
   AND(
      Time="90 minutes"
"Commission: 150",
   AND(
      Time="90 minutes"
"Commission: 140"
