Need help on formula
Right now we have a formula that uses percentages based on timeliness (Auto Calculated Percentage). This value is determined through a set of time between two dates. However I’d like to be able to override that for certain employees using another field like a checkbox or maybe a number field. So maybe an if statement would go in the auto calculated percentage? Like if override field is blank then use auto calculated percentage field? I can’t figure out how to do it
({Payment from Customer}*({Auto Calculated Percentage}/100))-{Admin Fee}-{Insurance Fee}-{Amount Paid to Employee}
Hi @F_M!
IF() formulas work as follows:
IF({condition is true/has a value},
   {do this},
   {otherwise do that}
In your case you need to create your new field of choice and then add an IF() statement to your original formula. This should do it.
IF({name of new field of choice},
(You have a random ‘(’ at the beginning of your formula. Check to see if this is a mistake just in your question post or if not all of your original formula was copied. Make sure that you use the whole of the original formula in your IF()-statement for it to work as desired.)
