Need Help With A Currency Formula
1025 2
Pedro_de_Nobrig
Hi There
I have a column (Net Sales USD/CDN) that is populated with various mounts. In another column (Currency) I have indicated which of those amounts are USD currency and CDN currency.
In a new column (Total Net CDN Sales) I would like to come up with a formula where it converts the USD currency amounts to CDN currency using a currency rate of 1.3 and leaves the CDN currency amounts as they are.
Your help will be greatly appreciated.
Thanks so much.
Does this look right?
24%20PM%201
Here’s the formula in the final field:
IF(Currency="CDN", {Net Sales USD/CDN}, {Net Sales USD/CDN} * 1.3)
Hi Justin
Thanks so much for the help, it worked.
Much appreciated.
