Need help with project management base; multiple projects, multiple phases
1381 4
Patrick_Fitzger
We are an architecture firm wanting to track multiple projects each with multiple phases so that we can project and manage resources. I know that there are many project management templates available; multiple projects with the multiple phases with begin and end dates for each is out of my reach. Would like to discuss if this is doable, then if it is worth it.
4 Replies 4
openside
10 - Mercury
10 - Mercury
Hey Patrick - happy to discuss it with you sometime next week. Reach out and find a time that works: https://drift.me/openside?schedule
Dan
Andrew_Johnson1
8 - Airtable Astronomer
Hi Patrick,
This is something that is well within my area of expertise and I would be glad to help you out.
You can reach me on andrewjohnson56782@gmail.com
Best Wishes,
Andrew
James_kevinn
Hello Patrick
I have expertise in such project, can we discuss?
Please connect on skype - james.kevinn
Hi Patrick
As a consultant and developer in data management, I can easily help. Let’s connect to discuss further. My email is nathalie@vacepro.com
Best regards,
Nathalie Collins
https://www.linkedin.com/in/vacepro
