Nested 3 IF() statements with 3 AND()
948 3
Julien_Reszka
What is wrong with my nested if? It says that that It’s invalid
  AND(
    {5dayswithnochange},
    {issueStatus🟢or🔴or🟠}=🟢
  "Stable ⚖",
    AND(
      {issueStatus🟢or🔴or🟠}=🟠
    "Stuck 🆘",
      AND(
        {issueStatus🟢or🔴or🟠}=🔴
      "Broken 🔥",
      "Too soon to tell ❔"
Julien_Reszka
nevermind, I forgot to add the quotes “” around the emojis :green_circle: in the equality evaluations
Correct code
  AND(
    {issueStatus🟢or🔴or🟠}="🟢"
  "Stable ⚖",
    AND(
      {issueStatus🟢or🔴or🟠}="🟠"
    "Stuck 🆘",
      AND(
        {issueStatus🟢or🔴or🟠}="🔴"
      "Broken 🔥",
3 Replies 3
Julien_Reszka
Correct code
  AND(
  "Stable ⚖",
    AND(
    "Stuck 🆘",
      AND(
      "Broken 🔥",
Glad you were able to fix your issue yourself!
However, I happened to see your formula and thought you might be interested in a slightly simpler version. This version has less nesting and eliminates the need for the AND functions. It also uses the SWITCH function, which is really useful for when dealing with multiple possible values for a single field.
IF ({5dayswithnochange},
    SWITCH({issueStatus🟢or🔴or🟠},
      "🟢", "Stable ⚖",
      "🟠", "Stuck 🆘",
      "🔴", "Broken 🔥"
Tank you! simpler syntax indeed.
