Not sure this is possible but I can’t seem to get this to work when I add the second part. I have a formula that works this way 'If Base Rate = 0 and IF UM= “Pounds” then Weight / 2000 * Price, IF Base =0 and IF UM= “Kilograms” then Weight / 2200 * Price, IF Base Rate = 0 and IF UM = “Each” then “Price”
I need to add this:
'IF Base Rate Not Equal to 0, and IF UM=“Pounds” then Set Weight/2000 * Price, IF Base Rate not eqaul to 0 and IF UM =“Kilograms” then Set Weight / 2200 * Price, If Base Rate not equal to 0 and If UM =“Each” then “Price”
