Nested IF and SWITCH driving me up the wall!
707 1
Safe_se
Hello!
I’m trying to use the nested IF function to return a specific piece of text per code that I enter (7 codes in total). I have tried to use both IF and SWITCH, and they seam to work for the first one or two and then I can’t get any further.
For example, these are the conditions I would like to have met:
IF{Indicator}=1, “A”
IF{Indicator}=2, “B”
IF{Indicator}=3, “C”
IF{Indicator}=4, “D”
IF{Indicator}=5, “E”
IF{Indicator}=6, “F”
IF{Indicator}=7, “G”
The letters (A-G) are just substitutes for text I would like to include. It’s one sentence per IF function - could it be a length issue?
I don’t know of any character limit for formulas so I don’t think that would be the issue. A SWITCH() function would look like this:
SWITCH(
   {Indicator},
   1, "A",
   2, "B",
   3, "C",
   4, "D",
   5, "E",
   6, "F",
   7, "G"
