Nested IF Statement For Greater Than Or Equal To
896 2
Rory_Sacks
Hi All, I am really new to formulas and I am trying to do along string IF statement. Can anyone help me identify where this is going wrong? I looked and read through other topics and just can’t get it to work. I essentially want this to go all the way from 1 to 100 with greater than or equal to all the way up.
IF({Security Price (from Search Criteria)}>85,“1”)
({Security Price (from Search Criteria)}>=70,<=84,”2”)
Use this pattern:
   {Security Price (from Search Criteria)} > 85,
   "1",
      {Security Price (from Search Criteria)} >= 70,
      "2",
You don’t have to check if something is less than 85 twice.
Rory_Sacks
This worked! thanks so much!
Is there an AverageA function in Airtable? I would like to average those cells that have the formula in it.
