Notify collaborators from an automation when a field changes
Topic Labels: Automations
1497 8
Tim_Page
Hi there, hoping this is an easy one but can’t see to make this run. I have an automation watching if a particular field is changed, and would like to then notify the collaborators who are assigned to that record either inside AirTables notifications or by email (am assuming because they are collaborators Airtable should know their email addresses).
Thanks
T
8 Replies 8
Hi Tim, hmm, I was able to insert a list of emails from a collaborator field and it seemed to work alright. May I know what issues you faced while attempting the following?
Screen Recording 2022-05-30 at 4.40.55 PM
Thanks Adam for the quick response. Here’s a quick screen video attached. Tells me the “To” input is empty.=
(Attachment Screen Recording 2022-05-30 at 5.25.09 pm.mov is missing)
Tim_Page
Screen Shot 2022-05-30 at 5.30.57 pm
Tim_Page
Screen Shot 2022-05-30 at 5.30.50 pm
Hey Tim, thanks for the screenshots. That’s…very very odd, your screenshots look like you’ve got everything done right
I’ve created a setup that works for me here for you to check out.
Hmm…I’ve occasionally faced some frustration with the trigger’s “Choose your record” data not being updated, so perhaps you could try selecting another record with a collaborator and testing the automation once more?
Hey Adam, just tried changing the trigger to another record, and it worked fine. Am guessing it might have chosen a record (chose random before) with no collaborator so got hung somewhere.
Thanks again. Looks like working now.
Tim
Ahh, glad it’s working
Tim_Page
Legend thanks so much.
