Numbers and currency fields treat blank as 0
1680 2
OneKlinik_Admin
I want to show a message if a number field is blank. 0 is a valid, non-blank entry. I’m using the formula
IF({Number}=BLANK(),"Blank","Not Blank")
where {Number} is an integer. What I’m seeing is that blank values and 0 values are treated the same in this formula. That is, the formula field shows “Blank” for both empty values and 0 values. I would expect this to show “Not Blank” for 0 values.
Screen Shot 2021-03-19 at 2.13.51 PM
Screen Shot 2021-03-19 at 2.13.58 PM
Conditional formatting will highlight only the empty values, which is what I would expect. So the concept exists.
Is there something missing or is this a bug? Any workarounds?
18 - Pluto
18 - Pluto
Welcome to the Airtable community. This is a known issue. The workaround is to convert the number into a string, and then test based on that.
IF( {Number} & "", "Not Blank", "Blank")
18 - Pluto
18 - Pluto
Thank you! That will solve my issue!
