Offline Forms Integration for Airtable
2197 2
Edward_Fisher
Hi there I was hoping to gather some feedback from the community regarding an integration we are looking at launching.
We are exploring integrating our software with Airtable so that people who require more complex, offline data capture (digital forms with logic) can capture information which then automatically synchs up with Airtable when connectivity returns. More here on our solution for context: https://vimeo.com/422707172
In summary Formworks allows users to create complex forms (which work offline) link to remote databases and also can apply logic to inputs when information is typed in by a user (calculations, acceptance ranges, workflows, hide and reveal, mandatory fields etc). In short it’s a very effective way of controlling data quality at the front end.
My questions is whether an integration between Airtable and Formworks would be of interest to Airtable users? Is offline data capture a requirement for many users? Your feedback would be very much appreciated. Thanks
Holli_Younger
8 - Airtable Astronomer
This would save me hours! Is it available yet?
LawsonChristian
It would save The City of New York hundreds of hours of work.
