On2Air Form Search logic help
719 1
Admin_REALTIMEB
Hi guys
Thank you for your help! and sorry for the noob question, but i’m struggling with below scenario:
i have a service provider that services multiple branches
The link on AT allows for multiple selections and all is good.
Using the fantastic On2AIr widget (subselect) i was able to easily pull all the providers affiliated with a specific branch by using : Child Search Field with “Branch Affiliation::Branch ID” logic
When a provider has only one branch affiliation results come up nicely, but once there are more than that no records are found.
So the questions is: What do i need to change in “Branch Affiliation::Branch ID” logic to allow for the multiple affiliation ?
thank you!
Hi @Admin_REALTIMEBOOKIN,
I think this is a question for @openside
