Origami Studio - Could not find field \"fields\" in the request body
Topic Labels: API
1976 1
Ignacio_Ceballo
Hello guys!
Im trying to create a record through the Airtable’s API but I can’t get it.
I am using Origami Studio and this is the message that airtable say:
“error” : {
“message” : “Could not find field “fields” in the request body”,
“type” : “INVALID_REQUEST_MISSING_FIELDS”
And this is my json
“fields” : {
“Name” : “Send”
So… why it is happening?
Thanks a lot!
Andrew_Johnson1
8 - Airtable Astronomer
One of the reasons you may be receiving this error is because you are not passing the data i.e
“fields” : {
“Name” : “Send”
in your request body.
Try calling the API via Postman or Curl…it would help you in figuring out where you are going wrong.
