Parent and Child Function Possible?
699 1
Walker_Talker
I have seen in this video My Workflow with Merch Wizard and Orbitkit Integration - YouTube
2:20 to 2:47 you have some functions you can make with air table, but I haven’t been able to figure that out. Basically, I want to create a parent child function.
And if there Is a parent, I want all the keywords to sum up in an extra column.
At 3:48 you can then select one parent or child and it will pull the keywords from one table to another.
Way above my head.
I appreciate all help.
Hi @Walker_Talker and welcome to this community!
May I suggest that you start of here and read up about how to link records in Airtable?
