63432members
147450posts
Community Activity
Downloading a PDF file from an Extension
Hey,I have an extension in Airtable that creates a file for each record within a Table. Is it possible to download each file as a pdf and populate a file field in the same Airtable record? Each file generated by the extension doesn't have a unique UR...
  • 9 Views
  • 0 kudos
Color records with a single select lookup field
What is the proposed idea/solution?When using a linked record and pulling over a single select field by using a lookup, it would be very useful to be able to color records with it. At the moment, it doesn't give you that option.For example, let's ima...
  • 13 Views
  • 0 kudos
Resolved! Phone Number to Plain Text Formula
Hello, I think I need a help of Airtable community even though there is built in AI helper in the formula field. Here is what I am trying to do and have no success for some unknown for me reason. I'm creating an automation that with the click of the ...
  • 29 Views
  • 0 kudos
bedjik by 6 - Interface Innovator
Airtable is now HIPAA compliant
喙 Exciting news for healthcare providers and organizations! Airtable is now HIPAA compliant and ready to support your critical work. We understand the importance of protecting sensitive patient data and maintaining compliance with industry regulatio...
  • 154 Views
  • 1 kudos
How to transfer record to another table on meeting condition?
Is there any automation in which I can transfer the whole record as it is to another table when it meets certain condition?Basically I have table 1 where once I click approved, the record should go to table 2. I am aware about the create a new record...
  • 39 Views
  • 0 kudos
Find record in automation using current record
I have a pre-filled form that is launched from a button in a record in the Assets table. When the form is submitted, the automation is triggered. A new record is created in the Updates table. Then, there's a Find Record step where a condition is ente...
  • 43 Views
  • 0 kudos
Help with Scripting to Add Totals by Commercial and Year in Airtable
Hello Airtable community,I am working on a project where I need to automate some financial reports in Airtable and I would like to ask for your help to solve a specific challenge related to conditional sums in several tables.Context:I have a base wit...
  • 37 Views
  • 0 kudos
Forms -
Good day.Looking to add to an existing form where we can rate each proficiency without having to create a field for every proficiency like this.  Typically, yes, there'd be a field for each proficiency with a single select, but does anyone know if th...
  • 42 Views
  • 0 kudos
Integrate UPS shipping tracking numbers to Airtable
Hi, I'm looking for a contractor that can build a integration into our Airtable that will automatically add tracking numbers from UPS for existing orders. We will have future follow on projects as well if we work well together, but this is a good fir...
  • 81 Views
  • 0 kudos
Announcements
喙 Exciting news for healthcare providers and organizations! Airtable is now HIPAA compliant and ready to support your critical work.  We understand the importance of protecting sensitive patient dat...
Announcements
Introducing Airtable AI
Announcements
Announcements
Announcements
