Populate column when filtered to empty cells
676 1
Zach_Polen
Hi All,
New user here. I would like to mass-populate a column after I have filtered to only the blank rows/records. When I filter to view only the blank cells and populate the first cell, it is removed from my view because it no longer is blank. Is there a way to filter to all of the blank rows and mass-populate these cells with the same value?
Hi @Zach_Polen and welcome to the community!
I always “sort” instead of filter and disable “keep sorted” :slightly_smiling_face:
