Possible to load an editable rich text field in a block, on record selection?
Topic Labels: Extensions
1327 5
Luke_McFadden
I’m transitioning from Notion, and REALLY miss a space for easy RTF notes. If I could select a record, and have it load a specific RTF field in a block, I think this could be a good workaround.
5 Replies 5
I think you left out a key requirement - to be able to edit that field in the block, right?
Yes correct! Being able to have a larger space to edit the RTF would be great.
Only a Custom Block is able to do this integrated into the Airtable UI itself. Alternatively, you could pass the content to an external web app/editor which would also write the changed content back to the record courtesy of the API.
Luke_McFadden
I did come across this today: https://devpost.com/software/knowledgeblock
This is 100% what I want, but without the depth of a wiki.
Yep - as I said - a custom block is how you get there.
