Thank you for your feedback, kuovonne, very much appreciated! I apologize for not replying sooner, I had gotten distracted with other things and hadn’t noticed your feedback until today.
I had not noticed the “Show code in public shares” toggle. That’s a big help!
You’re right; there were a lot of red bars in the code that were easily cleaned up. My next release will be syntax error free.
The script invocation was simplistic and didn’t allow for more than one record in the main view. A bit more effort would have fixed that. This is a shortcoming that I will fix in the next release. Rather than have a separate table of examples I will simply enable the code to use whatever row that the user presses the ‘Prettify’ button in, and move all the examples into main view; much easier to use.
Not handling field names without curly braces is a flaw. I’ll see what I can do about that. I will document shortcomings that I can’t easily fix for the next release.
The upcoming release I’m working on let’s you configure the code to output your preferred formatting. It let’s you change the spacing between elements of the formula, wraps long lines according to configurable parameters, and is better documented. It requires you to edit a 'configuration ’ function, but the edits are simple. Hopefully it won’t be too onerous. I’ll produce examples and perhaps alternate configuration settings that people can select.
Thanks again for your thoughtful and helpful comments. They are very much appreciated.
