Print not working
567 1
Babak_Eftekhari
When I try to print a grid view, the print dialogue box comes on, I chose all the options I want and then click on print. Normally this used to take me to the computer’s print dialogue. Since yesterday, it starts to say “printing” on the click box and then just stop doing anything else. I have tried to print using the App on a MacOS, on a Windows, and by logging into system via a browser. All the do the same. I have tried changing the options. Nothing works. It was all fine two days ago and then it suddenly stopped yesterday.
Has anyone else had a similar problem?
Jason
Airtable Employee
Airtable Employee
Hi @Babak_Eftekhari,
We did have an issue with printing yesterday that affected some customers (see a similar discussion thread here), but it should be fully resolved.
Could you try clearing your app/browser’s cache to see if that clears up the issue? Instructions here. :thumbs_up: If using the desktop app, you can click Help on the menu bar, select clear cache, and reload to perform the equivalent action.
