Problem with multiple-selection field ? How to repeat values
767 1
Iceshax_B
Hello.
I’m facing an issue with the “Multiple Select” field when adding multiple values (decimals) of the current price of the kW.
Sometimes, the kW price doesn’t change for the next two hours, so the value is repeated, but the table only saves one of them…
Example:
0:00 - price is 0.12261000
1:00 - price is 0.15979000
2:00 - price is 0.15979000
3:00 - price is 0.14321000
But in the field, it’s saving only: 0.12261000, 0.15979000, 0.14321000
Instead of:
0.12261000, 0.15979000, 0.15979000, 0.14321000
How can I allow the same item multiple times inside the multiple-selection field?
I’m adding the records using the API.
Thanks.
You can’t repeat values in a multiple select field. Sounds like you need to be creating new records (i.e. new rows) instead of trying to put multiple values within the same record (i.e. row).
