Dec 05, 2018 10:24 AM
Many of my records are trapped at the bottom of my base! Attempting to sort alphabetically by one of the key fields isn’t working! Why?
Dec 05, 2018 10:26 AM
What type of field is the one you are trying to sort by? What kind of value does it hold?
Dec 05, 2018 10:27 AM
thanks for fast response! The field is text - various publications, like NY Times, etc. I have reporters from different pubs, and the list is alphabetical by pubs.
Dec 05, 2018 10:28 AM
Strangely, when I attempt to integrated those records into the alphabetical-by-publication list, it won’t happen
Dec 05, 2018 10:29 AM
So the field contains text, but what TYPE of field is it? Is it a linked record field? Is it a Formula field? Is it just a Single-Line Text Field?
Dec 05, 2018 10:33 AM
Oh! I … don’t know. to the left of the field name is an icon representing a bulleted list, but I don’t know what kind of field it is.
Dec 05, 2018 10:35 AM
Like this?
yes. that’s right, it looks like that
Dec 05, 2018 10:36 AM
when I type in the name of a publication it automatically creates a colored button as field entry
So then your sort menu says “First-Last”, not “A-Z” right?
Dec 05, 2018 10:37 AM
Yes, it says first to last, not a-z
Dec 05, 2018 10:38 AM
Those are sorted by the order of the options in the Field menu:
You can alphabetize them by hitting that “Alphabetize” button in the Field menu options.
EDIT – It’s important to note that if you add a new Publication to that list, it will automatically go to the bottom of the list, regardless of its proper alphabetical position in the list; to have newly added options properly sorted, you need to repeat this process of hitting the “Alphabetize” button in the Field Menu options.
Ah!!! Okay, I’ll try…
Dec 05, 2018 10:42 AM
Well, strangely it didn’t work. they’re still down there. I wonder if they are somehow accidentally entered in some protected format, or were sorted as a group by some other field
Dec 05, 2018 10:43 AM
Re-apply the sort by clicking “Apply” in the Sort Menu:
EDIT – this can be done quickly in the future by hitting ⌘
/ctrl
+Shift
+S
(to open the sort menu) and then hitting enter
(to reapply the sort).
Dec 05, 2018 10:44 AM
Got it. okay will do
YES!! Success! it worked.
