Problem with Typeform integration with Airtable. I get duplicate records
471 0
Peerforum_Admin
Hi there,
I created a typeform that integrats with Table A on Airtable. The integration works perfect.
However, when I link Table A with Table B, the typeform integration breaks down and I start to see duplicate records. The first record is incomplete and the second one is complete.
Anyone experienced the same issue?
Screen Shot 2021-01-14 at 12.22.09
0 Replies 0
