Problem with using Airtable Lookup fields in Integromat
Topic Labels: Integrations
619 0
Ruchika_Abbi1
There seems to be a problem in using Lookup fields in Module settings.
I had a dev base which I used in Integromat and for that the lookup field shows up as an array and I get to select an item of the array. (See Screenshot)
Screenshot 2021-03-16 at 10.28.16 PM
However, I copied the dev base for production and now the same lookup field shows up differently. This causes problems in my Integromat scenario.
Screenshot 2021-03-16 at 10.28.27 PM
Stuck on this critical issue in Live system! Any suggestions appreciated!
0 Replies 0
