Problems with TEXT functions on LOOKUP fields
2586 4
Alan_Larsen
Help! Text functions don’t seem to work with a lookup field - FIND always returns 0, SUBSTITUTE always returns “#ERROR!” and so on…
4 Replies 4
I agree this isn’t useful or expected behavior.
However there is a workaround—append (or prepend) an empty string to your field reference and it will work.
This will produce an error: LEFT({Lookup Field},5)
This will work as expected: LEFT({Lookup Field}&"",5)
This will work with all string/text functions including FIND, SUBSTITUTE, LEFT, RIGHT, etc
That’s a great workaround - thanks so much!
Thank you for this. I was at my wit’s end when I came across this
Tim_M_GT
Wow, this is quite bad. :frowning:
