Project Management Template
1177 0
Pavan_Sarda
Hello Everyone,
We are in advertising business and we have similar repetitive tasks. For every client, we are planning to use Project Management base. Our requirement is that when I enter the record in Project Table, four Task should get added to Task table. These four tasks are the repetitive activities which we have to perform each time.
Hence looking forward to your guidance to know if I can prepare some template so that every time Project is added, relevant Tasks get added.
0 Replies 0
