Can you please tell me if there is a way to calculate the % of a project progress?
For example, can this be fone using the formula function?
Thank you
Thank you
So if you have a percent complete on each record, a super easy way to do this is to use the column summary bar: The summary bar – Airtable Support so calculate percent complete in a field then sum at the bottom in the summary bar
