Hello James,
Not sure about weather.com but if you are familiar with openweathermap.org, I have a script that can get their data.
First, head here to to get an api key.
let table = base.getTable('weather_data');
// NAME YOUR TABLE YOU WANT THE DATA TO GO TO WITH WHAT IS IN THE SINGLE QUOTES
let url = await fetch('https://api.openweathermap.org/data/2.5/weather?id=5392323&appid=YOURAPICODEHERE&units=imperial');
let json = await url.json();
//Name your columns 'weather.id', 'main.temp', the strings in the double quotes
//Loop over the json object (key/value pairs)
recordId = await table.createRecordAsync({
"weather.id": json.weather[0].id,
"weather.main": json.weather[0].main,
"weather.description": json.weather[0].description,
"weather.icon": json.weather[0].icon,
"main.temp": json.main.temp,
"main.feels_like": json.main.feels_like,
"main.pressure": json.main.pressure,
"main.humidity": json.main.humidity,
"main.temp_min": json.main.temp_min,
"main.temp_max": json.main.temp_max,
"wind.speed": json.wind.speed,
"wind.deg": json.wind.deg,
"wind.gust": json.wind.gust,
"visibility": json.visibility,
"clouds.all":json.clouds.all,
"dt": json.dt,
"sys.sunset": json.sys.sunset,
"sys.sunrise": json.sys.sunrise,
"timezone": json.timezone,
"id":json.id
A few things to note…
- This example uses my city code. ?id=CITYCODE
- Looks like you want a daily forecast. This will get current. If you poke around that link you will see many different options. For example, using this url fetch(‘api.openweathermap.org/data/2.5/forecast/daily?id={city ID}&cnt={cnt}&appid=[{API key}’) will get the forecast but the table columns might need to change a bit.
Good luck, If you run into problems let me know. I could share my base that you could copy if needed as well.
