Read data from barcode and auto fill-in the columns
801 1
Natasha_Iman
Hi. I have a project going on and I’ve been playing around with airtable for quite some time now. But I’m stuck at one idea which airtable to read data from barcode or QR code and then using the “linked” or “lookup” function to auto-fill the respective columns. Is that possible?
Regards,
Natasha
The barcode field should be your Link to Another Record type, and the Lookup fields should be pulling in related columns from the other table.
