Regex replace (or formula) find and delete multi strings
910 2
Patakess
Hello !
I’m looking for a solution to find the different strings in one fret and erase them in another.
For the moment it looks like this:
REGEX_REPLACE(Concat, Del,""))
But it doesn’t work if in “Del” I put:
8hKitchen 9hRoom
And in Concat
9hRoom 10hDiner 8hKitchen 11hBathroom
I would like to delete: “8hKitchen” and “9hRoom” (but it can also be of other occurrence, more or less.)
Someone would have any idea ?
Thanks in advance
18 - Pluto
18 - Pluto
Is this what you want?
RegEx can be tricky to craft. Your expression wasn’t working because the formula was looking for the exact string in {Del}. However, you want to look for any word in {Del} which requires a different approach. In this formula I use a RegEx to convert the contents of {Del} to a RegEx expression that looks for any of the individual words in {Del}, then applied that RegEx expression to {Concat}. I also threw in a little additional handing of spaces for good measure.
  {Del},
  TRIM(
    REGEX_REPLACE(
      {Concat},
      CONCATENATE(
        REGEX_REPLACE(
          TRIM({Del}),
  {Concat}
18 - Pluto
18 - Pluto
  {Del},
  TRIM(
    REGEX_REPLACE(
      {Concat},
      CONCATENATE(
        REGEX_REPLACE(
          TRIM({Del}),
  {Concat}
Thanks for your welcome !
And thanks for the answer. I would never have found! It’s work perfectly !
Thanks again !
