Regex to split string into comma-separated tags
1458 4
J_W1
My datafile has a field with multiple tags that are joined like this:
TagoneTagtwoTagthree
Is there a formula possible, with help of regex, to put a comma between all lowercaseUppercase instances to seperate them?
Kamille_Parks
16 - Uranus
16 - Uranus
Yep.
REGEX_REPLACE(Tags, "([a-z])([A-Z])", "$1,$2" )
4 Replies 4
Kamille_Parks
16 - Uranus
16 - Uranus
Yep.
@Kamille_Parks If you don’t mind, what you point me to a support article in which the use of variables ($1/$2 in your case for the capture groups) is described? I tried to find it just now and couldn’t… Thank you!
its not really documented, just noted that putting parentheses around a portion of a query creates a “numbered capturing group”. from there its extrapolating the relative order of each group you create preceded by a $
Thank you! (just adding characters to reach 20 characters… ;))
