Removing spaces from an ARRAYUNIQUE Rollup
1817 2
M_CCC
I’m going crazy trying to figure out how to remove spaces from this ARRAYUNIQUE.
Here’s an example of what I’m getting in the rollup field:
  • “5f286eebbd491e7410167db7”, “5f286eebbd491ee230167eaf”, “5f286eebbd491e8175167e8f”
I’ve tried adding another formula field alongside this to substitute the spaces using this:
  • SUBSTITUTE({Rollup Field},", “,”,")
But it throws an ambiguous error.
Oddly, it seems like the ARRAYJOIN is working fine. That defaults to no space, and it seems like you can run the SUBSTITUTE formulas over them with no issue.
Are there any known differences with ARRAYUNIQUE? Any ideas on how I can strip the strings from it?
  • Current output: “5f286eebbd491e7410167db7”, “5f286eebbd491ee230167eaf”, “5f286eebbd491e8175167e8f”
  • Desired output: “5f286eebbd491e7410167db7”,“5f286eebbd491ee230167eaf”,“5f286eebbd491e8175167e8f”
Thanks
18 - Pluto
18 - Pluto
You can nest the ARRAYJOIN and ARRAYUNIQUE together:
ARRAYJOIN(ARRAYUNIQUE(values))
By the way, using lookup fields in formulas is tricky because they are array values, not strings or numbers. You can force a lookup value into a string by concatenating it with an empty string {lookup field} & "".
18 - Pluto
18 - Pluto
Incredible. Thank you so so much!
Fortunately, that nested version works within the rollup itself. Much appreciated!
