Reset Checkbox After Click?
391 1
Julian_Patterso
My boss wants to use a checkbox in Airtable so a Customer can:
  1. Click the checkbox
  2. Receive an acknowledgment that the checkbox was clicked
  3. Reset the checkbox so it could be checked again by a different Customer to the same effect
Is this type of looping supported? If so, any idea what it would look like?
Welcome to the community, @Julian_Patterson! :grinning_face_with_big_eyes: Could you describe your use case in greater detail? While automations can be used to change field values (including checkboxes), your mention of customers changing these values brings up a lot of questions in my mind, mostly about the design of your base and where this checking/unchecking falls within the bigger picture.
