Restrict LOOKUP to record with max value in field
1705 1
Haydn_Sonnad1
Hello!
I’m looking for a way to restrict a lookup to only the record with the max date in a date field.
Context: Managing a vehicle fleet
Bases:
  1. Registration
    Screen Shot 2021-07-14 at 2.37.43 PM
  2. VIN
    Screen Shot 2021-07-14 at 2.37.49 PM
Desired outcome
Only display the license plate that is associated with the registration record that has the max “license plate exp date” value.
I’m not sure how to go about this. Seems like there may be a way to do so by
  1. creating a view in the registration base that only shows the records with the most recent
  2. restricting the lookup to that view
but can’t figure out the first step there.
Any help appreciated.
18 - Pluto
18 - Pluto
See this thread, but do the latest date instead of earliest date:
18 - Pluto
18 - Pluto
