Roman Numeral conversion
836 2
Andrew1
Hi all,
I am importing a data set that stored some numbers as roman numerals. Is there a formula or other method to convert these to numbers?
This would only be possible with a custom JavaScript, since Airtable functions do not support iteration.
Here’s one that I found on the web:
Others here can likely help you integrate it into your system.
Perfect, thank you Scott.
