Run Automation by Script
1501 4
wjb
Hello. I have a series of actions in an Automation set up to create records (tasks) when a new project is created.
Sometimes there’s a snafu and the project is created accidentally or there’s a mistake. Meaning I need to re-run the steps in the Automation but they won’t run again on their own.
I thought I could create a script to choose a record (Project) to run that specific Automation that creates the records (Tasks).
Is this possible or would this all have to be generated by a script?
TLDR: Can you run an Automation selectively by a Script > Record Picker
4 Replies 4
Technically. Your script could turn a checkbox “on” for that record, and set the automation to run when records with checkboxes ticked.
Oh wow, I like that better. Thanks for the simple solution.
Any chance you know if my (more difficult) original question is possible?
Nope. The only way to trigger an automation is to make some change to a record, or to create a record.
Thanks for the clarity.
