Running email automation for existing records
Topic Labels: Automations
543 1
Daniel_Becker
Hi All,
Hoping for a quick answer as I cant find it through search.
I have an existing base and table that has already been populated by form entries.
After the fact, I created email automation to email based on specific criteria.
It seems that the automation only works on new records as they come in. Is there any way to push the automation to run on existing records in the table?
In Hindsight, I should have set up the automation before but it’s a bit late now.
Hey Daniel, I’m afraid not. Usually when this happens to me I just add a checkbox field and make my automation trigger “when checkbox is marked” to get the old stuff out of the way
