Running IF function if fieldvalue is correct
869 3
Mikko_Mantere1
Hey,
I need to create a formula something like this:
If field_1 = “text_A”, then;
If field_2> field_3, “Text_B”, “Text_C”
Otherwise “Text_D”
I don´t know how to do it and I couldn´t find from community or google…
Anybody?
Thanks
//Mikko
Here’s another possible interpretation.
  {field_1} = "text_A",
    {field_2} > {field_3},
    "Text_B",
    "Text_C"
  "Text_D"
3 Replies 3
This is a simple nested IF() use case, or a use case for AND(). Search for “nested if” for more examples.
Your example formula can be interpreted one of two ways. I’m not sure if you want to output a semicolon if the first input is true. If so:
      "Text_B",
      "Text_C"
If not, then:
   AND({field_1} = "text_A", {field_2} > {field_3}),
   "Text_B",
   "Text_C"
    "Text_B",
    "Text_C"
  "Text_D"
Mikko_Mantere1
Thank you! :pray:
it works nice!
//Mikko
