Same colors in a row
1318 2
Megan_Feasel
Hello!
I’m looking for the ability to create colored fields (colored rows too) and have them be the same color in that row. I have a large table and I need certain fields to draw the eye. I created a couple of single select fields which I’m settling for until Airtable [hopefully] comes out with a better option but my question is, is there a way to make all single select fields in the same row the same color? Right now if I want to do that it would be a terribly long [and painful] manual process of changing every single select field in every row. If this option is available I would LOVE to know about it, if not, Airtable is it something that is in the works?
I don’t understand. Why do you want to stand out those rows? Can’t you use a View? An image would help.
Oh, and you can change the value of a select Field in several Records at the same time.
Nathaniel_Weave
I would also like this feature as my shop staff is always asking me for highlighted versions of our project lists.
