Schedule backups without scripts or code using Make/Integromat and CSV Getter
771 1
GavinA
8 - Airtable Astronomer
This process is now VERY easy using www.csvgetter.com
Checkout my demo video
Willem_Dewulf
Looks great and easy indeed :slightly_smiling_face:
For those we are looking to back up more data types than just the records, I would highly recommend the backup integration that our team has built for Airtable: It automatically backs up your records, comments, files & field configurations and syncs a copy of your backup to dynamic Google Sheets.
Of course, this solution is not free like csvgetter so if you just need your records, then the solution above will do just fine :slightly_smiling_face:
