Script Block 1.2 - Template is not working
Topic Labels: Extensions
540 0
Candace_Strickl
Please help! I cannot figure out why the first task is just repeating in the Next Task column (To Do Tasks table) when I run the script. It was running perfectly and then I must have changed something in the Projects table - No Tasks view(?). I don’t see where the mistake is though.
The script is very long, so I’m not sure of the best way to share it.
Here is the New Tasks part of the script:
New Tasks
And the table screenshot:
Table Screenshot
Any help is appreciated!
Thanks
0 Replies 0
