Script - Covert string to number/integer
1127 1
Ujval_Shah
I am using a script feature to add data in the table. One of my field type is “Number”. Data coming from the API is in string.
Hence, its not allowing me to add the data in AT, showing error - Error: Field “fldqIRRqhaalc20cqo3” cannot accept the provided value.
const myNumber = Number("123")
