Script Errors: 15 mutations per second, and Slow Run-Time
1532 3
Dean_Arnold
7 - App Architect
7 - App Architect
Hi there,
I adapted the below script by @Justin_Barrett. Everything was working great until I added a few hundred new records to the ‘TaskLog’ table.
The script now throws this error:
Exceeded quota of 15 mutations per second at main on line 20:
let result = await table.selectRecordsAsync()
In addition, the run time is now 23.8/30s - also an error for my purposes - as any run time that goes over say 6-seconds will make the script unusable.
Can anyone tell me exactly how to edit the script to include batch processing or another solution that will solve the two errors at hand?
Ideally, the script should be able to quickly search through thousands of records in the TaskLog table in order to mark the ones that match the Account ID from the first step of the automation (inputConfig.AccountID)
Here is the script:
// Remove all existing markers (ie make all Task Log records 'current' value null)
let TaskLogTbl = base.getTable("TaskLog");
let TaskLogRcds = await TaskLogTbl.selectRecordsAsync();
for (let record of TaskLogRcds.records) {
        // Change Current field value for all records to Null
        TaskLogTbl.updateRecordAsync(record, {
            "Current": null
let table = base.getTable("TaskLog");
let field = table.getField("Account");
let inputConfig = input.config();
let inputValue = inputConfig.AccountID;
// Load all of the records in the table
let result = await table.selectRecordsAsync();
// Find every record we need to update
let updates = [];
for (let record of result.records) {
    let originalValue = record.getCellValue("Account");
    let recordValue = record.getCellValue("Account");
    if (recordValue == inputValue && originalValue != inputValue) {
        updates.push({
            fields: {
                ["Current"]: null,
    } else if (originalValue && originalValue != inputValue) {
        updates.push({
            fields: {
                ["Current"]: "1",
    // Update records - Only up to 50 updates are allowed at one time, so do it in batches
    while (updates.length > 0) {
        await table.updateRecordsAsync(updates.slice(0, 50));
        updates = updates.slice(50);
The issue is resolved.
There were some blank Account records, so when changing the script as below, everything goes smoothly.
let updates = [];
let recordValue = record.getCellValue('Account');
if(recordValue && recordValue[0].id == inputValue) {
updates.push({
fields: {
["Current"]: "true",
}else {
//For all other records to have current value as null
updates.push({
fields: {
["Current"]: null,
3 Replies 3
You have two places where you are updating records. The first time you are updating records one at a time (updateRecordAsync without the s) without the await keyword.
Rewrite this first set of updates to use batches (updateRecordsAsync with the s) to match the syntax of your second update.
Or do a rewrite of the script so that you only update the records once instead of twice.
Hi @kuovonne
Taking your advice, I ditched the first part of the script and tweaked it as below. That solved the mutations error, but I can’t get the script to find or mark the ‘Current’ field as expected.
let updates = [];
if(recordValue && recordValue == [{id : inputValue}]) {
        updates.push({
            fields: {
    }else {
	updates.push({
            fields: {
                ["Current"]: null,
Could the reason be that the ‘Account’ field is a linked field and the script is not matching the input variable (A record ID itself) to the ID of the linked field?
In the hope of matching one to the other, I’ve also tried this:
let recordValueid = recordValue[0].id;
if(recordValueid && recordValueid == inputConfig["AccountID"])
I got an error saying: “Cannot read property ‘0’ of null”
let updates = [];
updates.push({
fields: {
}else {
updates.push({
fields: {
["Current"]: null,
