Scripting block and Wildcard?
1277 2
Albert_belingar
Hi there,
i’m looking a way to export a table in csv.
that’s pretty easy
The trouble is that certains field (adresses for example) contains comma.
i wonder if there is wildcard or regular expression in the scripting block.
i aint found it in the docs
thanks !
Stephen_Suen
Community Manager
Community Manager
The scripting block supports vanilla JavaScript APIs, so you can use regular expressions!
Stephen_sue,
Thanks a lot
