Seems it might be helpful to add 'excel formula translation' to formula reference documentation and base
just a column that has the excel/google sheets equivalent of the airtable formula for the people migrating to have a more seamless transition. something that says 'if this is what your formula in excel looks like this is the formula you need to use in airtable. or @kuovonne is this something that could be an app? or even included in readymade formulas
There are too many differences between Excel formulas and Airtable formulas to make a direct conversion. Excel has several functions that do not have Airtable equivalents. Plus, Excel’s ability to reference any cell or a range of cells doesn’t translate to Airtable.
