Set default view for embedded block
678 0
BrettP29
I am trying to embed a block on my page, the “Page Designer” block to be specific, and when it gets embedded it does not hold onto the selected view. It defaults to the first view in the table (Master View). I would like it to automatically load with a different view selected (Print $150) as that view contains the records the Page Designer should print.
I have tried setting the view in the block itself inside airtable but it doesn’t stick for the embed.
Any ideas? Thanks in advance!
chrome_j3mPnfs7lR
0 Replies 0
