What you’re asking for is stretching the limits of what the Scripting app was meant to do.
Save for automations, another approach that comes to mind would be Promise-based, but it sounds like it’s time you graduate to writing custom apps, anyway.
Because even a command as simple as “wait for one or the other” isn’t as straightforward when dealing with JS’s single-threadedness. There’s one kind-of-native approach to dealing with it, though: the Promise.race method.
I just pulled this code from an older hobby project, cleaned it up as best as I could and confirmed it works in the scripting app:
class Frame {
static menuBar = () => input.buttonsAsync('',['Option 1','Option 2'])
// @ts-ignore
static idle = (ms) => new Promise(resolve => setTimeout(resolve, ms || 2000, 'timeout'))
render = async () => {
const
buttons = Frame.menuBar(),
interval = Frame.idle(),
raceWinner = await Promise.race([buttons,interval])
output.markdown(`# ${raceWinner}`)
await (new Frame).render()
I’ll probably open-source the whole thing eventually but the gist of it is that these 18 lines do exactly what you said, with the exception of the timeout duration - it’s set to two seconds here.
And yes, these are technically two frames, hence the reluctance to share this unfinished work haha.
The final line of the Frame.render method also illustrates how you can access the value of the async function once the race is done.
But again, it sounds like you might want to look into custom Airtable apps. Doing something like that in one of those is trivial because React pretty much does the state management for you, whereas here you’d just be using my own inferior take on React inside the sanitized Scripting app environment.
Also, this sentiment cannot be overstated enough but let me try, aynway:
creating a blocking (sleep mode) in a non-blocking script environment is ill-advised
