Shortcut for moving between rich-text fields
What shortcut can I used to move forward and back from a long text field that has rich-text formating enabled?
I usually use tab & shift-tab to move back and for between fields when I’m entering data. However, when I hit a rich-text field, the tab creates a tab within the field and doesn’t move forward.
Is there a way to do this?
