Simple project management
1485 6
Nikki_Elbaz
Hey all,
I need a simple project management base.
I want to be able to view things by deadline or by category, but I also want to be able to dive deeper into each day or category.
It’s not a complicated set up at all – I just don’t have time to figure out how Airtable works.
If you’re available ASAP and budget friendly, reach out. :slightly_smiling_face:
6 Replies 6
Ian_Radnor
Hello @Nikki_Elbaz
Greetings
Would be glad to assist you.
Kindly join me on Skype (live:ianradnor088)
Regards
Ian R
Hi Ian,
My existing base isn’t organized very well. I started with an Airbase template and tried to add fields and links myself. I think there are some redundancy and I don’t want to start deleting fields. Also want to see if the content of the email I write to someone will show in the records. i am in So Cal… where are you located?
Dianne M
Hello Dianne
Kindly PM your email id so i can sent you my understanding and quires about the project.
Ian R
Andrew_Johnson1
8 - Airtable Astronomer
Hi Nikki,
I should be able to help you out on this, as its well within my skill set
Feel free to reach out to me on andrewjohnson56782@gmail.com
Best Wishes,
Andrew
Hi Ian you can reach me at dianne@havlusport.com
Anonymous
Not applicable
Hi Nikki,
I’d be happy to discuss this with you further via phone and provide you a price and timeframe. Could you schedule a call with me via this link: https://calendly.com/ericwebdesigner or you can email me at eckline@gmail.com
Best,
Eric
