Simple way to highlight duplicate entry
3184 3
PainMed_Adminis
@ScottWorld , I went through a few options to look at ways to just highlight the duplicate entries as they get entered into a database. I noted u came up with a simple one but there were no steps written down.
We have a unique patient ID which is in the primary column , we dont want to duplicate a patient file. Every time we enter we wish to have a look and see if there is a duplicate entry and delete if its highlighted. makes sense?
3 Replies 3
That is not possible with Airtable’s native capabilities. You can search for duplicates after the fact with Airtable’s DeDupe app:
@ScottWorld thank you.
Hope we get s solution in the future. :slightly_smiling_face:
ggarofalo
Agreed!  We need to see if something is going to be duplicate when it's entered into the database / table immediately!  Highlighting or something would be key!
