I pasted several records into a grid, as I have done in the past (nothing has changed that I know of). Now, the grid view no longer shows the text of the Select (dropdown) item for the inserted records (existing records are showing the text).
Odd thing is the values are indeed there (and I can see them listed when going into the Customize Field Type option for the Select). The text in the non-Select fields is showing, so it just seems to be something glitchy with the visual for the grid view on Select fields. Again, the text is there (and I can see it if I create formula fields based off those fields). When I try to remove the colors, I just get grey boxes.
Any idea why this just started happening?
I have tried scrubbing the original data and making sure there is no trailing spaces, etc. and re-pasting it. This is really odd since I have been doing this a lot for several years and have never seen this before. So, any advice on what could be causing it would be greatly appreciated.
Hello Marin,
I just copy/pasted one record including a single select field and the new record shows the text.
Did you try wiping out cookies and all? Airtable uses local browser features, sometimes one could get in a wrong state somehow?
If the text is there but yet not visible, one improbable possibility is the text being somehow assigned the same color as the background, so you see all in uniformity. I don’t know how the text color could be set, don’t see an option for that.
Maybe you tried it already, but in this supposition, you could change the color of an option - turn a light-colored one into dark-colored - just to see if the text retains its current color, differentiating from the background.
Last recourse : make the field simple-text and then turn it back to single-select. Chances are it will return to show as expected onwards.
Great to hear! As in the movie, gremlins only understand the hard way…
Please mark my last post as Solution
so others with a similar issue will know this thread contains a help for them.
